by Goldenblack440 » 23 Mar 2009 16:15
yes, thats about the cam i have and i also used the dual plane and Thermoquad. They are great for torquey takeoffs, which you need with a heavy car like this I also port matched my inlet to the heads. Very easy with aluminium. Just buy a cheap Chinese die-grinder and use an old inlet gasket and plenty of WD-40 and you should get an extra 6-10 HP, It should also make it rev a little easy up higher, which is where these older design intakes start falling over
