FC7RT wrote:Thanks for your help,i have changed my order to the comp cam hyd roller 242/248@50 292/300 duration 1.6 rollers give 585/580 lift,just got back from a cruise here in melbourne australia and a guy had his 570 cube camaro with big solid roller and it was rediculous,700hp+,cant make it along to the fire charity cruise next week because he does not have the range in fuel to participate,not interested in that kind of bs thats why i like to keep my combo real.What do you think?Comp said its worth a little more hp and tq without giving up anything.
I too am going to use a hyd. roller! in my 500" stroker!! It gives the best of 'BOTH' worlds. Yes, it is quite expensive compared to a flat bottom cam, but it can be ground with the power producing 'squared' lobes as Solid roller cams have, flat bottom cams cant have this radical interface due to the lifter bottom and the lobe, it makes this physically impossible. You'll have a nice reilable powerplant that makes great torque and exceeds your H.P. target, probably by a wide margin. The important thing to remember here, is the idle will be much improved over a flat tappet cam with 'equal' proportions. The driveablity will be much improved, the engine 'quieter', no need for ANY breaking in, no worries about flattend cam lobes, you can use any lubricant you wish, with moly filled/faced rings, tri-metal engine bearings, breakin will be almost instant, I am using an Australian Made RollMaster chain with German chain,(Iwis), and this also needs no breakin due to the chain and rollers being polished before asssembly. So you can assemble the engine ,, fill with 10W-40 or whatever you wish as long as the bearing clearance isnt over .003 and burn rubber!
(I have personally discussed this with 3 members on this board who have wiped cams, (flat bottoms), and had to tear the new engine back down). Smart Move!! Keep us posted on this build, I would love to see/hear it after/during it's completion! Thanks
