Goldenblack440 wrote:That is very great and comprehensive info - I certainly hope Adrian reads it.  Eddie, what do you think of Sealed Power rings - not sure if they even still make them.  I think they were all file fit? Also, Perfect Circle rings - they don't use a normal gap?
 Perfect Circle and Speed-Pro are both good rings. Ive used them both with great results. I personally like the Ductile Iron Moly faced or moly filled rings. The moly face have a Plasma-Moly coating placed on the top ring face. Plasma-Moly filled have a top ring thats actually 'filled' with the moly face coating on the leading edge. I dont know which is better to be honest. The last 3 engines I have built, a Ford 394 stroker and a Chevy 350 LT-1 both used Speed-Pro and Hastings Rings. I liked them both! My 500 Stroker used Total Seal ductile iron top ring plasma moly filled, standard barrel faced top ring, cast iron 2nd, stainless steel oil ring package. Keep in mind there are a myriad of choices in piston rings, backcut, beveled, barrel faced, chrome, ect,, it can get kinda complicated at times.
  I dont think you can get much better than any of the rings you or I mentioned, they are all good quality with race proven results. The most important thing is the bores are straight and true, the bore finish is correct for the coating or material you wish to use, the top ring gaps are set with enough clearance or gap to ensure they dont 'Butt' at higher operating temps. This is VITAL on hyperuetectics than any other piston type as they expand much more at the pistons crown or top of the ring groove more than any other piston design so the top ring gap must be increased a few thousands more than usual. The Chevy I re-built had hyper pistons with only .010 top ring gap clearance. I knew that because it was the only piston that wasnt damaged, they rest were damaged very badly, the block had to be bored .040 to clean it up,(they got lucky), it had less than 20 miles on it before it siezed-locked up.
 The 'gap' depends upon both the ring manufacturers and piston manufacturers directions. As in the hyperuetectic pistons which require a larger top ring gap. In this case, whatever ring you choose, you must follow the pistons direction first and foremost. "File fit' rings can gain power because each bore is gapped according to it's size. pre-gapped rings are a hit and miss deal, some bores may have a larger or smaller gap than others. it wont be a lot, but when you are building an engine for a very low leakdown rate, thus more cylinder pressure, the hand gapped rings should make more power. The factory of course didnt do this. There is power to be had from 'blueprinting' the pistons, bore, rings, rods crank ectt.
