i have forgot one part of information i need to ask you i got the disc brake swap set up off a 73 duster. but do i need to change the master cylender to the booster are can i just use the one i got thank you randy
Posted: 23 Feb 2009 2:11
by drewcrane
i would change the master cyl. and the proportioning valve too!i had a duster and did the swap , but i used all the components associated with a disc brake set up , just to make sure everything is all the same
