 by Hans » 26 Jan 2002 16:17
			Here's that article I meant. (out of Big Block Mopar Performance written by Chuck Senatore)
...The 440 Block - Though any 440 block will physically work, there are a few year-to-year variations that are worthy of a closer look. There are three different 440 blocks that you will encounter in your junkyard. The first type will be found with casting dates from mid-1965 until mid-1968. These first series are a thick-wall design and will make a good starting point for your engine. The next series goes from mid-1968 up through 1975 and are the same as the earlier blocks, but have additional stiffening along the outside in the form of cast-in ribs. These blocks are the best to use. The third series of blocks will be the 1976-1978 blocks which have a thinner cylinder wall design. These thin-wall blocks still have the external stiffening ribs but they don't have as thick a cylinder wall as the earlier blocks. This isn't really a problem but keep the overboring on these to .030" or less. This does not mean that these blocks should be avoided. On the contrary, many killer engines have been built with these later blocks as they still have the same bottem end strength...
...Selecting overbore size - Make sure the overbore you have selected won't leave the cylinder wall too thin. If you have acces to a sonic checker, make sure that the cylinder walls are at least .080" thick after boring. This is considered a minimum and any thicker is better, especially for performance use. All the thick wall blocks can be safely bored .060" over. Some of the early 400 blocks can actually go .100" over but sonic check first. The later model thinn-wall blocks should be limited to a .030" overbore. If the water jackets have been filled with cement, the overbore can be increased. Even the thin-wall blocks can go .060" over with no problem if the block has been filled. This a race-only modification. Also remember to check the inside diameter of the head gasket that you you plan on using to be sure that it will accomodate your desired bore size. Don't forget to make sure that there are piston rings available too.
