I am having a problem fixing an oil leak on the drivers side of the engine.It appears to be coming from the center intake bolts because the 2 center pockets on top of the manifold are collecting the oil. I have tried using a high temp thread sealer which may have slowed the leak some.
When I put the bolts back in they were torqued to 35 ft lbs which is what was called for in my old Chiltons Manual. Is this a common problem and what might be the next step at correcting the problem. The engine does have an aluminum intake. Any suggestions are appreciated.
