by DanaProsky » 13 Aug 2008 1:21
Yes, mine is an aftermarkt setup. I was trying to do what you said, line up the two front drain holes, but it does not fall in place, it stays up just enough that you can not bolt the bubble to the base plate, I think it is hitting either the Shaker doors or the air filter lid, so something is not right. Being that alot of the Shaker parts were missing when I got the car,I had to buy the Shaker air doors, hoses, cables, etc, so I am learning as I go on how to get everything assembled and working the way it should. With everyones help, I'm sure I'll get it together.
