airfuelEddie wrote:Yes. And no you dont need the most expensive!
Wayne if they are old and crusty they probably need changed. . I would get a set of black MSD 8.5mm Super Conductors if OEM originality isnt a problem, if you want the original look you can get a set from various vendors in the UK I'm sure. Maybe Dave has a good supplier.
I prefer MSD but thats just me Wayne. There are other good wires. I use MSD on both my gas vehicles. As the wire gets old the conductor gets brittle, burned, resistance increases as heat increases and they can no longer insulate as well when old&crusty. Plus they scatter the spark all over the engine bay when faulty and old. You should see it in the dark!
there was a test done on new plug wired, they tested a new one, and the the guy whipped it one time on the table , the wire lost half of its capacity, the thing i learned , if you pull the boot of , and dont stretch the wire, its ok, but after a couple 3 years i will replace mine as i will this week end , ,cause the boots have gotten soft, and they deteroiate ,and dont insulate as well, i also use msd stuff, it seems to last the longest,one of the problems we have here in colorado, the humidity was 6 percent on saturday i kid you not 6 percent, so our bodies last , but all the rubber , and vynal bits dry out , and rot so we have good rust free panels but our interiors dry out, as well as wires, etc, sorry for the ramble i gotta get to work!o btw we have only had 3.6 inches of rain since january 1 st!
