RPm drops under hard acceleration
I have come into problem with Rpms. During hard acceleration let assume i start second gear 2000 rpm i put pedal to the metal rpms goes up to lets say 3500 and then they go back by around 200 rpms During this time engine is stumbling, after that they start to go up again very fast and very good the engine pulls very good.
Timing is set to 35 deg total advance, i am running speed demon 650, primary jets 70 secondary 78, squirter no 31, accelerator pump 30 cc, 0,5 inch spacer, mixture is set correct as i see the color of plugs coffe + milk. Engine is 318, with 360 heads , 2,02 valves and hughes engines camshaft 2328, performer RPM intake. KB dome pistons with compression 10,5:1, i am using 98 octane fuel.pover valve i 4.5, vacum at idling is around 14 inch
With all above and street tires, and 3.23 rear end the car was doing 14.2 quarter mile.
Does anybody have a clue how to solve this matter ?
