by Eddie » 10 Jul 2008 17:52
I would pull the 8 wire connector under the steering column and see if the ignition switch wiring has 12 volts going to it,(The yellow wire), I believe, maybe Dave or someone else would know offhand for sure, but I think it's the yellow wire. If you get 12 volts then the wiring to the switch up to that point is OK. The only thing left would be the wiring to the switch from that point,(under column harness connector) ,to the switch or the switch itself.
