by drewcrane » 20 Jun 2008 19:41
may be you are getting spark , but how much spark i had a car with a questionable system and it had a spark but not enough, however not to confuse you but it was on a 6 volt system , on a 41 ford,but just the same it should lite, if you have spark,this kinda stuff can be mind bending,it may need to go back to the begining carefully looking over everything you have touched, and double check them again,good luck!
