My sending unit has two outlets outside of the gas tank. I've got the 3/8th inch line running to the carb, is the other for venting? I have seen a venting line running from the fuel filler tube down to the sending unit in the tank. Is this necessary? Car runs without it, but put gas in today, just above a ½ tank, and of course since I forgot to block off the second line, and the fact the gas expands in the tank, I got to clean my garage floor when I got home. My filler tube is not drilled out, and I really don't want to unless it is necessary.
My real question is, can I just block off this line with a small piece of hose and some clamps, and just drive the car? Just want to be certain I am not doing any damage. Thanks all.
