airfuelEddie wrote:See how many non-correct things you can find! You can also see the other downspout hose on the right side. The left side exits right on top of the heater hose bracket. I wont be driving in the rain however.
ed,i guess you want to know what i can spot that is non stock. here is what i see. msd 8.5 wires and brackets set around the headers. shaker drain hoses cut. non stock battery. battery tender is on charging
it seems as though your shaker sticker does not have the small lines on it,is it the photo or a different sticker? everyone knows though that you have some nasty stuff inside that motor
tire shop
yes goodyear loves me. all 4 of my cars run on goodyear tires. 70 chevelle and chally have the repops and 2002 vette and 2007 gt500 have the formula 1 goodyears.
yes your right the front snorkel grills are cast iron inbeded into the fiberglass shaker bubble.they are heavy.
my car has the original hoses for the shaker rain drains.the right side goes down between the power steering unit and water pump and exits down below parrallel to the bottom of the rad. the left side has a factory bend that exits over by the big hole at the bottom of the fender area. both hoses are pretty long in size. they also make it a pain in the a@@ when putting on the bottom plate.
