Could be Pat. A vacum leak is cause for concern on any throttle body system as they are sensitive to vacum leaks. Multi-point injected vehicles arent. On a TBI system it will make the engine run rich, PIG rich!!patrick wrote:Maybe a vacuum line popped off?
Adrian, if you want the best in Torque and fuel economy, Fuel Infection cant be beat!! No Joke man. You will lose maybe 1-2 mpg if you switch to a carb, also the alternator is regulated by the PCM so some extra wiring and a 1970's electronic voltage regulator will be mandatory. A new intake, custom made throttle cable and it aint fun in your vehicle to 'get right' this is from personal experience. I had to use a LOKAR assembly, the stock cable setup will not work. It's lot of work and money for almost no gain. Yes you're 318 is different, it has a hydraulic roller cam but non magnum shaft mounted old style rockerarms, kinda of a hybrid in anticipation of the 'magnum's' that eventually replaced the LA style engines.Adrian Worman wrote:Hi ya mates
Got problems with my Dodge Ram 250 dayvan,1990 wirh a 318 E.F.I and 3speed auto with overdrive. It keeps stalling when coming to a stop, in really bad cases when speed drops to 10-15mph. Little tickle on the throttle usually catches it in time, getting quite exciting lurching toward stationary traffic at junctions. Happens frequently now so checked over usual stuff like basic tune and service items, checked condition of smog hoses and wiring but no improvement.I got a spare 600 Edel. with electric choke I'm quite happy to stick in place of the E.F.I Any thoughts? The trans hangs onto 2nd gear quite badly but if you let the throttle off it changes up fine,that can be fun.
Now little doggies fixed its a shame its such hard work to drive. Any ideas greatly appreciated as always.
Cheers, Adrian
If you choose this option call first and see what the price is, also most electrical sensors are easily damaged installing/removing, the parts jobbers look for blade insertion by the little scratches on the blade contact tips so find out before doing any purchasing. If I had to 'bet money' on this I would pick the Coolant Temperature Sensor, ECT is what Chrysler calls this part. The code for a faulty ECT is code 22 .
No problem Adrian, glad to help! Try spraying out the throttle bore with gumout or other carb spary cleaner this always helps with the idle..Keep us posted!Adrian Worman wrote:Hi Eddie
I can't seem to get any light to cume on when I cycle the ignition key other than oil pressure light.I must pull the dash mouldings off and gheck all the bulbs behind the guages.
Pulls really well off the line and kickdown,does'nt struggle on any hill or strong headwind and allways feels really torquey, even on light throttle.
Won't have any time till weekend but I'll keep you up to date with my progress.
Thanks again for your time and patience Eddie, your a star !
Adrian
Adrian, just to make sure we are on the same 'wavelength' as an understanding the flashes are "flash" "flash" "flash" pause "flash" flash"=32 OK? Now, on what I interpret from what you have written is a code 31 and a code 12 is this correct? If so it means the battery power has been temporarily disconnected at some point in time,(code 12), and the other code is the purge solenoid electrical circuit is in a grounded or open condition. The first code is nothing to be concerned about. The second code,(31), simply means a wire has been broken or the connection has been unplugged. The purge solenoid is critical to a good idle, check the hoses that lead to the charcoal canister in the cavity behind the passengers side headlight, make sure the vacum hoses are intact and not split. There is also a hose from the intake manifold to a round metallic canister,(The purge solenoid itself), that has an attachment bracket to the exhaust manifold, this hose may have become split or removed. The EGR, Purge solenoid, and charcoal canister work as a team to burn raw hydrocarbon emissions either into the engine or stored for a burn at a later time when there is too much HC in the canister. Try this test, disconnect the hoses from the charcoal canister, if it improves the idle my theory is correct.Adrian Worman wrote:Hi Eddie,
Just finished repairing dash lights and have managed to get the check engine light to come on. I've read the codes as best I can and they:-
3 (which you have told me might be 1 followed by slight pause then 2). Then 5, long pause. 8- long pause. 4 -long pause. 7- long pause. The last code is 10 which appears to be the finfishing code which you described as 5 and 5; there is only a very slight pause between the two 5's.
While I had the dash apart,I found a piece of loom with a multi plug on end and on back of dash pad there was a piece of printed circuit board that when held up to light I could see some warning symbols showing through.I don't know why it would have been disconnected but when fitted dash together I installed plug and now when ignition turned on as well as the check engine light coming on the other panel flashes 'maintenance required'.
"I hope I've interpreted the flasing codes correctly as it's hard to judge the short pauses.
I appreciate all your help and if anything makes sense out of this and could be of use let me know.
Thanks again
Adrian
It comes on at automatic intervals of 45k, 75k, 105k, 145k miles (these are approx #s).
