For the most part Yes. As Dave has mentioned, properly 'prepped' they will all flow pretty good. A used set of heads re-conditioned with new one piece stainless steel valves, the factory used a regular steel two piece valve with the head and stem friction welded into place,(Scary huh), hardened exhaust seats for running hard on unleaded pump gas without having to worry about valve seat recession which takes many miles and heat to do this, new springs, valve seats re-ground, possibly new or re-sized guides, will add up quickly so the cost will almost be the same for a used set to a new aftermarket set. Head work is vital for a strong plant. The magnums will require oil through pushrods and lifters, but this is no biggie, they flow enough box stock for 400-450 H.P. as the 5.9 crate engines are producing this from the factory with a decent sized camshaft. It's easy to wrap up 2000.00 into a set of fully ported/prepped new or used castings, but remember you can do all this to a set of questionable used castings and they crack on the first outing and your day is ruined. New is always better! I really like the Hughes Engines Heavy Duty Magnum Head for LA or Magnum plants. It's cast iron head and a bit heavy but it's a decent price for 227 CFM flow,(enough for 475 H.P. with the right cam, and more available if ported, it's got dual closed chambers with a small chamber easy to build comp. with a flat top or mild ratio with a dished piston like the OEM design, hardened seats, high velocity ports), great street head! The '308' casting heads are almost 20 years old and will be harder to find in good shape, they were used only on fuel injected 360's truck/van chassis from 88-91 only. I used to have set, wish I still had em!
