I am in the process of rebuilding the engine on a Massey Ferguson tractor with a 3 cylinder Perkins Diesel. I discovered some abnormal wear on one of the rockers. The valves were pretty loose probably .060 clearance and thus this damage occurred. I thought to grind the tip flush but am concerned about losing hardness in the metal. The valve tip seems OK no mushrooming but maybe i should replace them also.
Also on one of the tappets there is a flat wear mark on the face. I doubt it is spinning at least not consistently. Think the cam needs to be replaced also?
