I have a warm 360/904 going into a 73 Challenger, hi lift cam (2700-5800). The heads are small port smog heads. i have port matched the Edelbrock Performer inlet to the untouched heads. I have just got some headers. They are 1-5/8 primary. The exh ports are smaller, so should i port match these as well? Someone told me not to- to leave the step which creates an "anti-reversion" effect. Any idea if this is correct- benefits? etc
What do you reckon Eddie?
PS, the exhaust system is going to be a twin 2-1/2 with X pipe and low restriction mufflers eg Lukey straight through or Flo Master. It won't be anything fancy like mandrel bent. I hope all this will still have enough backpressure to give the torque i need? As i want driveability, its a heavy 3800+ car. i'm hoping the inherent torque of the 360 will still be there
Thanks, Steve
