Welcome, sounds like a nice set-up! Any pics? Usually a miss at high RPM's that doesnt exist at lower or cruise RPM's is either fuel or ignition related. Sounds like a bulletproof ignition! What is the timing set at now? Did they re-place the timing set? It's easy to check if there is any slack in the chain by popping the cap and observing the rotor move with the crank turned over with a breaker bar. There should be very little deviation in movement, very little!! What type of plugs do you use? Have you pulled them to see if they are tan/normal and not white and lean? How big is your fuel line and the pickup tube in the tank? Is this a prior V-8 car? Did this just start after a fresh engine re-build? My plugs were a tad to cold so I went to a one step warmer plug and it cured my fouling problem. More info would be appreciated.suikishell wrote:Hey everybody..love this site, like reading random posts and threads..very good and engaging contributors. So..my 74 Chally was running very nicely. But lately it seem to be missing ever so slightly on kickdown. High rpms,, back off a little right back to normal. It has a 360 built, port matched and polished 750 edelbrock, edelbrock DP manifold and an MSD ignition, iwas thinking maybe a little timing adjustment, would that be normal? Thanks in advance,
Yep, Graduated there with a 4 yr. B.S. in Criminology.suikishell wrote:Ipulled the plugs and they dont look fouled or anything i will pull them again and check the heat range, and address the other items in your response. Thanks Eddie. Terre Haute...Home of I.S.U? I grew up in suburban Indianapolis. hoosiers...good folk...again THx..
suikishell wrote:Thanks Dave, Its an edelbrock 750. Any pointers..Keith
