Page 19 of 26
06 Jan 2009 18:09
Here is something every big block MoPar engine builder should have. It took some researching to find it.
14 Jan 2009 1:03
These exhaust ports look a bit 'off'
14 Jan 2009 1:04
With a gasket. I think one port is just a bit smaller on the exit than the port itself. I took many measurements and the port was just 'cut' a bit smaller, I'll equalise them during the gasket match.
14 Jan 2009 1:09
Valve spring height averaged 1.880 using my Goodson's valve height micrometer. The worst one was .010 shorter at 1.870. The springs checked out at 130lbs. seated pressure,(closed).
14 Jan 2009 1:11
The valve seats were cut spot on with exhausts at .060 and the intakes at .040 I checked them all using Prussian Blue and 'lapping them' to see the pattern.
14 Jan 2009 1:15
Valve guides were excellent with around .0008 clearance,(they made that perfect "thlunk" sound). I may omit the exhaust seals.
14 Jan 2009 1:21
I still need to pressure test the heads.(I should have done that first but I was too eager to take em apart
), CC the chambers, CC the exhaust and intake ports. I bought a CC'ing Burette from the Sciencemall.com for 68.00 bucks complete kit with burette, stand, clamp, petcock, glass not plastic, 100ML, so I'll have to re-fill it during the intake port meausrement, no biggie, I wasnt paying 300.00 for the other tool suppliers for the 200ML!! After all thats done I'll put them on the 'HeartBreaker"(@28") and of course I'll post em on here 1st!
14 Jan 2009 6:20
by patrick
14 Jan 2009 9:20
Working in the University I never had a problem getting a 100cc burette.
Never needed the 200cc one because I only ever did chambers. Never measured a port.
14 Jan 2009 22:40
Oh, I forgot to mention open pressures. The installed height averaged around 1.880 I deducted .600 and Compressed them in the Rimac to 1.280 the readings were HIGH=326 LOW=317 result the springs were within 5%. I am using other springs,retainers and locks. This is to let Ian and MoParMan1972 of the results. Be advised 440source claims the ret.locks,keepers NOT to be used above .515 even though the springs will allow .600 before coil bind which occurs at 1.110,,
14 Jan 2009 23:02
by Moparman1972
Thanks Eddie, I had seen that. I am probably going to go with heavier springs.
15 Jan 2009 12:11
Here's what I tested the springs on. The new digital Rimac on the left is what I used. I couldnt see the scale on the older machine to the right. My 'bi-focals' havent gotten in yet.
15 Jan 2009 13:37
by ianandjess
thanks eddie i did see there claim & went for a comp cam 507 int 510 exst just to be safe i probably should pull the heads down & improve them (i know i should) but ive blown enough dough just doing what ive done so theyll have to do for now , ill use them as i bought them & in the meantime ill keep teaching myself stuff on cheaper locally available before i make any serious mods to parts i need to import ( the freight is a killer) once ive got it done & on the road ill be able to relax & take advantage of what ive learnt from this board & other sources this is all great info it keeps the brain ticking over thanks eddie
cheers ian
15 Jan 2009 13:50
Those sound like the same springs I have on my engine Eddie.
15 Jan 2009 18:07
Thanks Dave&Ian, I think there is enough spring for most apps up to .600 Lift. I bet you have much better quality retainers and Keepers than whats on it now Dave. These arent Chrome-Moly retainers or keepers, they're stamped steel, therefore they have the .500+ lift 'disclaimer, but with the cam you are runnning Ian it should still be fine to 6000 RPM's. Same as the factory stuff.
29 Jan 2009 18:04
I had time to flow the #3 Intake/Exhaust port today. I couldnt use an entrance radius on the intake port because my instructor would not allow it. He was afraid the manometers would be contaminated if dirt or contaminates were flowed pass the screen into the meter vanes, so NO radius, it would have flowed much beter with it in place but here's what I came up with. At .100 the flow= 115CFM at .200=153CFM at.300=205CFM at .400=223CFM .500=235CFM .600=237 CFM the exhaust was very strong compared to the intake, of course I didnt use a pipe, just the exit of the port. .100=84 .200=133 .300=168 .400=190 .500=198 .600=206
29 Jan 2009 18:15
Also, the round clear plastic orfice is all the adaptors we have, it's 'bore' size is 4.25 so the bore is definitely shrouded and this also may affect the flow, maybe MoparMan1972 would know? I aksed the instructor if this would affect the flow and he said it sjouldnt that much but I suspect he is misinformed. He isnt that knowledgeable about performance. He;s a dealership technician, as are all of the instructors. The area of maximum performance and just 'fixing' things are completely different. I am learning a lot and plan to make subtle mods as well as finsihing flowing all the inatke/exhaust ports to establish a baseline on which to make further mods. The first thing I am going to do is backcut the intakes, then flow it to see if I picked up any additional flow. I mean to backcut ever so slightly, just placing a radius on the valve head, or 'ski jump' as the grinders/cutters refer it to. An interesting thing is I had to flow these smallblock Ford,(Aussie made Pro-Comps)
heads along with mine. The intake ports were the same almost with 210 CC intake ports mine at 212 and his valve was a smaller 2.08 compared to my 2.14 and the ports flowed virtually the same CFM. I would have thought they would have flowed worse through the smaller valve. This made me believe the port shape and valve seat were key in the flow numbers along with the reduced bore size.
29 Jan 2009 18:16
All my exhaust ports were CC'd and they were spot on at 72CC.
29 Jan 2009 18:17
Shazaam! This FlowBench be loud man!
29 Jan 2009 18:18
Sorry no readout graph from the computer. As soon as they figure out how to use it and teach me I'll post the Official results but this should whet your appetite. Also, I really dont care about the numbers, I want to establish the baseline and futire mods to progress forward in flow insteadof going backwards. I am very excited that they let me even use this flowbench. Now that I have a 'semi-handle' on things they are going to have to pry me off this thing!!! I even snuck the operators manual home with me, and the software Discs, I want to learn everything about this machine!!
29 Jan 2009 18:25
I forgot to put a sparkplug in at first and had to start over!
I also used a standard 440 gasket,(4.340 fel-Pro blue for the seal to the adptor plate to the bottom of the head, I checked the seal leakage rates and it was at 0%
29 Jan 2009 18:54
by fbernard
airfuelEddie wrote:I aksed the instructor if this would affect the flow and he said it shouldnt that much.
I think it won't matter much too.
If you were measuring air flow through this tube, going from 4.25 to 4.38 would be a 6.2% increase in section, and so a 6.2% increase in flow at any given vacuum.
But what you're measuring is air flow through each valve and the port which precedes (or follows) it. The shape and size of the simulated combustion chamber is not too relevant, as long as the pump can create enough vacuum or pressure to take the maximum measurement.
I think the length of the tube would have a much bigger influence over the results than having a tube with a 4.38 bore.
29 Jan 2009 19:33
fbernard wrote:airfuelEddie wrote:I aksed the instructor if this would affect the flow and he said it shouldnt that much.
Thank You Fabien! I am always impressed by your knowledge!
BTW, Fabien, I have a packet in the manual I brought home. It contains 2 pitot tubes to measure airflow stagnation and velocity. It also has a chart with density/temperature . I am reading and it seems very important to port development! I can find the airflow stagnation points in the port. I have to say, this flowbench can suck up to 1000 CFM's and it will literally pull your hand in the orfice! I had the airflow calibration set to 300 CFM when I tested that Intake/Exhaust port. You can put the airflow setting as close to what you think the port will flow maximum. This way the readings are more accurate because the parameters are within it's range of measurement. At least thats what the 'directions' said,
I'm still learning so much. I want to graph this all on paper, then bring it home and set up my own file and record the changes on the PC. Thanks for the input.
29 Jan 2009 19:38
Also if there was something I could use that attached to the port with enough adhesion as to not get sucked into the port opening, the instructor was nervous when I attached some silly putty to it but I took it off because he thought it would get sucked into the manometers, which are screened,(calibrated for the screen obstruction to airflow), and mess things up. Any ideas? It's gotta be pliable enough to shape into a radius, test, then remove without damaging the head or soft alloy.
29 Jan 2009 20:01
I just read this in the manual Fabien. I think the school needs to get a much larger adaptor plate.
It's standard 4",(4 inch hole into a 4.030) tube, then the gasket which is a standard fel pro blue 440 gasket at 4.340, then the head. It needs to be much much larger! Thats why the intake side was so weak I assume. The bench sucks through the intake port but blows through the exhaust port. You have to switch the settings when testing. I also had the stting on 300 when it should have been 400! Oh well, I am learning and having a blast!!
29 Jan 2009 22:02
Whew! I was WAY off! here's what Superflow had to say about radiused intakes. Up to 30% OFF!
30 Jan 2009 12:49
by ianandjess
add 30% to those figures you got & theyre not as bad as you thought
can you shape a piece of perspex to give the desired effect 1 of the aticles i read recently sugested doing it that way
cheers ian
30 Jan 2009 14:26
ianandjess wrote:add 30% to those figures you got & theyre not as bad as you thought
cheers ian
I asked him about that Ian and he suggested modeling clay. All I had at the time was silly putty, kids crap. It crumbles to easy. I'm gonna pick some up today at wally world. You have to have somethng that mimics the walls, roof ect exactly, only something thats pliable yet sticks to the sides all the while conforming to the shape of which each port has minute differences so a tooling plate will only be a burden. Plus when I start 'hogging' out those ports I'll need to expand it all the way around the circumference of the shape. I'll keep you posted on what I find out and the results after I get this figured out. BTW, what is perspex?
30 Jan 2009 15:09
When the machine was running I took a small ink pen and probed the walls and roof, floor, ect,, even small obstructions produced results that are eye opening, dramatically changing the flow! It shows just how 'sensitive' airflow really is. It also shows how much momentum and how heavy air really is. This guys sells a kit for 1k
www.flowperformance.com
30 Jan 2009 16:27
I once again called Steve Brezinski at SuperFlow and he sent me this parts list for the adaptor plate and cylinder spacer tube plus gasket. It comes to 731.00!! I sure hope the school will approve it's purchase. I also called some acrylic suppliers for the option of buying it myself and cutting it to fit my application. At this point, I am on a buying freeze. I cant buy any more parts or tools, instead saving for a special project of which I have comitted myself to financially.
