1). Three Bolt cam drive instead of one bolt.
2).Valve stems were flash chromed
3). Premium crankshaft forging
4). Connecting rod forgings were heavier and wider beamed than 'LY" 440 rods were
5). Hi rise dual plane intake with three Holleys instead of standard dual plane with Carter AVS
6).Camshaft was increased in duration and lift with high rate valve springs with damper.
7).Recessed faced Crankshaft Damper was used that compensated for the increase in connecting rod weight
Can anyone else add anything??
