Correct fule line hose.
Postby RedRaven » 02 Nov 2007 20:29
Guys Im in the process of repalcing my fuel line from pump to filter to carb, what diameter line should I use?
I was going to use 6mm line, will this have any bearing on the amount of fuel getting to the carb ie too much/tooo little?
RedRaven
Postby dave-r » 02 Nov 2007 21:08
I keep forgetting. It is a 440 yes?
If so then 3/8-inch internal (9.5mm) line prefered.
Postby RedRaven » 02 Nov 2007 21:10
dave-r wrote:I keep forgetting. It is a 440 yes?
No its a 383 :oops:
RedRaven
Postby dave-r » 02 Nov 2007 21:15
Ah. See my memory?
Just keep the same internal diameter as the i.d. of the pump outlet.
Postby dave-r » 02 Nov 2007 21:16
But go a little bigger than 6mm so 6.5 or 7mm minimum. :wink2:
Postby RedRaven » 02 Nov 2007 21:33
Check!! :thumbsup: :thumbsup:
RedRaven
Postby Eddie » 03 Nov 2007 12:29
Let us know Wayne. Then Dave can give you a how to on the Drum brakes. He's a better writer than I! :wink2:
