HI, can anyone versed in camshaft specs and appliction tell me what they think of this combo?
SPECS of the Cam i am thinking of using: Erson Hi-Flow Hydraulic, Advertised Rev range: 2700-5700, 0.472/0.472 lift, Duration at 0.050": 228, Advertised Duration: 296, Centreline 108 degrees, 0 advance.
CAR: 73 Challenger slapstick auto
ENGINE/BOX/DIFF: Nothing too special about the engine: Freshened 360 + 30, new standard late model J heads but unmodified, new CompCams springs, single with damper (120 seat, 320 open), standard exh manifolds with twin system and balance pipe, Edelbrock Torquer single plane, 4 barrel carby, probably a Thermo quad (there's nothing wrong with these). TF904, rebuilt with modded valve body, fresh "Morestall" converter (2500 stall), 3.23 rear (8 3/4" diff)
WHEELS: 14 inch rims
Because i am selling the car as a running, registered vehicle, this is a budget build up with parts i already have. The cam is old technology but if i don't use it now it will never be used. I'm a bit worried about the large weight and the sort of take-off grunt the cam will be able to deliver.
Any opinions on how it will go in this car? I know it will never run 13's at the drags but i'd like a perky takeoff, not a boggy one. Thanks for any advice. PS, i won't be fitting extractors or doing any other engine work.
