On the way home this weekend I broke a valve spring. No racing, took it to 5000 RPM's maybe once or twice. It has happened before and I have several spares but am thinking about replacing them all.
Could there be a coil bid problem or do they just get old. These are 20 year old Sig Erson or Isky (can't remember which) but a second set from the originals for sure.
The more research I do to find a set, the more questions come to mind. Dual spring, seat pressure, coil bind height, spring rate. The cam is a MP 284/.484 lift so extreme spring rates are not necessary or desired given the old aluminum retainers. (I may replace those also, it's no fun ending a nice day on a sore note).
Anyone have information on this subject. Oh, small block 340, with factory iron heads.
Thanks
