It could possibly be a wiped lobe. Your observation of the rocker arms lack of movement confirms this. I would drain the oil and expect some metallic slivers or dirty clumpy oil. I would also cut open the filter for a see. If it's a wiped lobe the oil pick up will also be clogged. Bad scene man. Can you observe the pushrod? Is there any up/down movement from it? If not, then it's possibly the cam lobe.rtse4406pack wrote:hey guys thanks for all your tips. i took the valve cover off today to have a look at whats going on. turned the car on and found that one rocker does not go up and down,push rod is straight maybe lifter is gone or cam lobe? it is the second rocker from the end at the firewall side. smoke only comes from the last exhaust hole on the exhaust manifold. also my motor was recently rebuilt as that is what the prevoius owner informed me today as i just got this car last week. still can not figure why the blue smoke and it does not clear up as i drive it just gets worse. it is not a gasket leak. also some oil actually seeps out of the exhaust manifold on the top of its gasket. hopefully these clues can help you understand more about my problem. looking forward to participating on this forum. other than my motor problem the car is a beauty.
The intake has got to go!(for an inspection)
hi dave,that sounds like a great idea,i will take photos so maybe we can work things out together. hopefully a little help from my challenger freinds will go a long way. cheers guys!!dave-r wrote:Take some photos of what you can see and show us.
hi guys-i have found the problem (i think) pulled the lifter out and the lifter was worn bad on an angle at the bottom of the lifter, also the cam lobe is rounded. checked the valve seat from the same rocker and it is actually ok as it moves up and down like the rest of them do when applying a lot of pressure along valve spring. drained the oil and took off the oil filter and no filings was found. well i now have to take the cam out. guys you think i should take the heads off too? also where are the antifreeze holes on this motor,i was told there is no antifreeze in the intake,is that true. is there antifreeze in the heads-if so i will drain out all my antifreeze. attached is some photos so you can better understand what i am talking about. you guys have been great in helping me. now lets get a little bit more help from my freinds.rtse4406pack wrote:hi dave,that sounds like a great idea,i will take photos so maybe we can work things out together. hopefully a little help from my challenger freinds will go a long way. cheers guys!!dave-r wrote:Take some photos of what you can see and show us.
airfuelEddie wrote:I think the 'oil' may be unburned fuel.Re-check that valve Danny, if it's smooth and un-interrupted and the cylinder holds good pressure then disregard the head pulling part.
hi guys,what do you think of this choice of cam and lifters from comp cam. Camshaft Specification TableairfuelEddie wrote:Excellent Danny, I like Comp Cams products but Hughes Engines has good ones too. More importantly, the proper breakin is a must! The problem stems from the lack of high pressure additives available in todays eco friendly lubricants. I would use a high quality oil that has these additives. I use Amsoil and Amsoil filters, also the lifters are not made by Johnson anymore from my research into this. It seems the lifters have become "softer"? but you are not alone in this problem. Many pro-engine builders will not build an engine without roller lifters anymore due to this problem,( hydraulic roller lifters are avilable for the B/RB engine they are not cheap), another rather expensive but permanent solution to this scuffing problem is Shubeck Lifters in both hyd. and solid but they are very expensive 800.00+ a set I believe. They are indestructible and can be used over and over again with different cams even in different engines.
