http://www.440source.com/heads.htm
I could swap over everything from my existing heads to those if I wanted to.
drewcrane wrote: run cooler too!
drewcrane wrote:ya know ,dave if you could have gotten the alloy heads when you built your engine , would you have gotten alloy heads?. one thing for sure a person could run a much higher compression with alloy heads, than with cast iron heads right?,
I was afraid of that. That would have 'tapped' my limited patience!dave-r wrote:Lots of issues. They guys are morons.
To be fair though the Mopar pulleys had not long been out when I got mine.
3 or 4 wrong power steering pulleys later (plus customs charges at my expense) I finally gave up and altered my PS braket to line them up.
Yes and No. The aluminum alloy is not as thermally efficient as cast iron. The heat being 'absorbed' reduces this power. So you have to increase the compression to remain at the same power production capability as the cast iron. 3-5 lbs lighter huh. Cool, that would help with accelerating out of the corners Drewdrewcrane wrote:the march kits are a total kit, they are about 3 to 5 lbs lighter, also the pulleys are less rotating mass, dave doesnt the benefit of higher compression make more power? i understand cylinder pressure is important, as is piston design etc. , but higher compression makes more power
drewcrane wrote: i understand cylinder pressure is important, as is piston design etc. , but higher compression makes more power
