I'm having a problem stopping my engine from back firing when accelerating have tried setting the timing at 12 Degrees BTDC as recommended by a fellow mopar guy. Then tried changing one degree at a time until I was advanced at 4 degrees TDC, still the problem has not gone away. The car idles good and when I accelerate slowly I have no problem. But when I accelerate quickly it back fires and stalls. The distributor, the plugs, the EI Module, wires, rotor and cap are all new. Still the problem exist. So my question is before I take everything apart. Can it possibly be the CAM or the timing chain or possibly my carb. The carter which was originally on the car is gone, replaced with a holley 4bbl about 3 years ago.. Any ideas?
 Rob
		 by Rob » 12 Dec 2001 14:34
