I am thinking that with that cam you would need a 2800 to 3000rpm rated stall speed just to make it drive normal.
However I don't think a 2800 will quite cut it in a small block.
I had the same sized cam in my 440 and the 2800 rated converter was just right. A small block will stall at a lower speed which is why I suspect you might need a looser converter than that.
The cam duration @ .050 is about 241 degrees with that cam so it is on the lumpy side.
You will need 3.55 rear gears for the axle.
Maybe someone that has used the same cam in a small block can comment?
Another thing you can do is call a convertor company and ask them. They advise on these things as it is in their best interest to supply you with the right converter first time.
Also try contacting Graham aka "Transman" on here. I bought one of the converters he uses. I have not tried it yet but I was impressed by the company website. And the service of course.
