by Dave R (Roppa440) » 27 Feb 2002 9:11
Adding one bit or another to a stock system rarely produces much in the way of power gains. Engines have to work as a SYSTEM. Each part has to be matched with another.
In fact in some cases adding a performance part by itself can result in less power.
However in the case of header exhaust pipes you WILL get an improvement with this one simple change. Even though you will not get as much benifit as you would by adding a matching cam/heads/intake it is still the best place to start when looking for performance as non of the other performance parts work well without headers.
The performance gain will be around the 20hp mark with no other changes.
What you will also get is an increase in under hood temperature, more noise, and - if you buy cheap headers - leaking exhaust gaskets.
