Wojpi wrote:When i start engine cold i got 60 psi at the idle, that is set to 800 rpm
until 70 deg C of engine temp is keeps that way, When i reach around 80 deg C pressure at the idle drops to 40 psi, during drive aroound 200 rpm there is 60 psi, when i reach 90 deg C at the idle i have 35 psi and around 55 psi during drive at 2000 rpm.
Nothing to worry about. Keep the oil temp below 90 degrees C though. That is too hot. You need to be closer to 80 degrees C.
180*F is the ideal temp. That is 82*C. The hotter the engine gets the thinner the oil gets as you have found.
My little 318 puls 14,4 s for 1/4 mile on street tires and the car has all equipment in it the weight with me in is 3750 pounds, and i have 3,23 gears, i was using 255/60 tires.
Do you think if i use 275/60 tires my ET can be worse ?
A wider tyre will give you more grip. But the 275 will be almost one inch taller so you will have slightly higher gearing. One probably offsets the other.
What kind of power this engine can be putting ?I have never checked it ?
To work out what power your engine is making I need the mph at the 1/4 mile.
From your ET of 14.4 and your weight I can tell you that you are making almost 250HP between the tyres and the track surface.
So you are probably making
at least 320hp at the engine. Not bad at all for a 318.
But your mph will tell more.
