Hello everybody,i found this forum very interesting and i hope someone has some helpul tips for me.Challenger has a 440 bored 0.60 w KB pistons. Old but ported stage4 heads and a Weiand dual plane intake.Cam is Hughes 2330 Int504/Exh515 Dur at 0,50 223/230 ,hydraulic lifters,stock exhaust manifolds.Carb is Edelbrock AVS800 with stock dual snorkel and KN filter element.Mopar electronic ignition upgraded with weights advance lighter spring inside.Despite to almost factory look under hood the engine when running unveal some healty power.The big problem is it really smells bad of unburned fuel although it doesn't smoke at all.I tried to lean idle mixture screws as much as possible and to chance initial advance from very advanced to quite retarded but didn't get it running crisper and cleaner. i don't want to steal you more time,any help would be appreciated. thanks Roberto
