I will install quanta fuel sending unit.
http://www.quantaproducts.com/prodinfo. ... SUCR8-12SS
I will build the new 1/2" aluminium line with the electric pump near the tank and I want to use the stock metallic fuel line to return the line from the firewall.
Do you think it's correct?
The stock fuel line has moreless the same diameter like fuel sending unit return inlet.
