JimiBoy, I am no expert but I stayed in a Holiday Inn!
seriously, The Edelbrocks, Dave Hughes Heavy Duty 360 magnum Heads, MoPar Performance Big Port Aluminum Commadoes, all are very good choices for street and strip. My choice for a "killer" street engine Small Block would be a 360 Block LA or Magnum block doesnt matter. 4.030 Bore Honed with Torque plates, mains checked, then get a 4" Cast crank form eagle or M.P. performance, ARP main studs, Hughes girdle if you are going to rev it past 6500 RPM, Eagle H-beams for high revs or re-conned stock 360 rods and Keith Black pistons Speed Pro or Hastings rings 1/16 size,(O.E.M.), or buy a new short block for 1299.00 (USA prices). Heads: Big Port Commado,(good valve job, combustion chambers relieved around the intake side especially, no porting as they dont need it!), Hughes 290/.580 cam,Edelbrock Air-Gap Holley 770 Street Avenger. Easy 500 H.P. 450+ Torque from 408 cubes and the torque curve is nice and flat no need for 4.10 rear gears. The cam you can live with on the street without "loading up" cause the engine is much bigger than the small block you started with! If I had the money,(soon), I want to get a shortblock and build my other stroker which I want to build very similar to the one above.
