440 parts worth much
PostPosted: 20 Jun 2007 21:44
This is a set of 440 valve covers and my original bellhousing. Are they worth much,(like a used set of INDY 440-1's in cast iron),? Or just keep em for another 5-10 years. :mrgreen:
PostPosted: 20 Jun 2007 22:33
by JDB840
The bellhousing might be worth keeping. A couple of years ago my u-joint gave out and cracked mine. I would've loved to have an extra to put in it's place. Instead I had to fork out 400 for the lakewood bellhousing.
PostPosted: 24 Jun 2007 1:18
by MLMFLCN
Eddie,
How much would you want for the valve covers? Would those clear a set of Harlard Sharp 1.6 rockers and a mild comp cam (274/286)?
Thanks,
PostPosted: 24 Jun 2007 2:17
Thanks for the interest, but I'm afraid it wont clear the Harland Sharps. Thats why I went with the MoPar cast aluminum valve covers. It wont clear my Comp Cams Pro-Magnum Rockers and they are smaller physically than the Harland Sharp units I think. The stock valve covers have an oil shield welded inside them so oil pullover wont be a problem through the P.C.V..and into the carb. This shield interferes with the rockers.
PostPosted: 24 Jun 2007 11:28
by jh27n0b
Eddie, Does your wife know that you are using her living room table as a work bench? If those are original to your car, I would hang on to them. Just my opinion.
Bob
PostPosted: 24 Jun 2007 14:21
No she doesnt! If you tell her, I'll invite her over to your house during supper. You will be cleaned out my friend!! :mrgreen: Seriously, I think I will keep on to them. The bellhousing is original to the car, not the valve covers.I was wrong about fitting under stock valve covers though. A friend e-mailed me that uses Harland Sharps and he also uses the stock covers and the Mancini Racing catalog shows them to fit. I was just curious as to the value. What I really need are Jack parts,(the hook, Jack assembly and spare tire). I dont have any of that stuff. I was thinking of trading parts actually.
PostPosted: 29 Jun 2007 1:13
by MLMFLCN
Hey Eddie,
Called Harland today and they said the covers need to be "tall" ones and that stock will not fit. :s006: Oh well, I will go with a set of the tall jobbers. Thanks,
