I have redone 318 engine. It has :
Keith Balck dome pistons
Compression ratio 10,5:1
360 heads, with big valves and porting done,
MSD 6 A ignition ,MSD distributor (non vacum type), MSD wires and coil
EDELBROCK performer RPM intake
SPEED DEMON 650 carb (stock specs) vacum secondaries
TTI exhaust system with Dynomax mufflers
Hughes engines camshaft 223/228
The engine is going nicely, i have the vacum at the idle 850 rpm around 15 inches, in the drive it is 11-12. What is my concern is that at low rpm when i start to drive it is like not to good, but when the rpm increases lets say more than 4000 rpm it starts to pull like hell. It revs up to 6000 Lets say from the start to around 60-70 km/h at first gear it is not to good but suddenly it starts to pull like hell, and what is strange when i change the gear to higher one it is not droping power but continue to pull.
When i stop and start again it is the same. \
What do you think can be the problem.
Thanks in advance for any suggestions.
And the "big" question is what rear gear do you run?
