I have installed my rocker arms (Harland Sharp, 1.6 - 440 engine), and on the passenger side, all of the arms rock back and forth with no effort (push rods are not in yet, having them custom cut). On the drivers side, nearly all are binding somewhat, yet move with a small amount of hand pressure. The heads are 452 castings, so the pedastals are cast in. I can see where the shim/washers on the rods ride agains the pedastal (see pictures below, much worse on the drivers side). All of the rocker tips seem to line up with the valves pretty well.
First question, like the heads, there is not a passenger or drivers side for rocker arm assemblies, right?
Second question, I suspect that there should be zero binding on these, do I need to buy a shim kit for these and adjust where needed on the drivers side only?
Harland website has very little tech support, just an observation.
Thanks again for all the help!!!
