hi when i replaced my headers i noticed coolant leaking out from the bolts in the heads. does all the headers bolts go into the coolant channels in the heads? or just the once in the back ?
thanks
dave-r wrote:Anything really. Gasket sealer for example.
dave-r wrote:I forgot to say. Yes you just top it up via the radiator. But run it up to temp with the cap off and the heating on full and top it up again if the level goes down. Then stick the cap back on and check the level again after using the car for a run out after it has cooled off.
There is a drain cock at the bottom of the radiator to drain the system. Some water always stays in the block though.
dave-r wrote:Stock exhaust manifolds (not called headers) are held on with studs and nuts. Not bolts.
