I am assembling a 440, and am about 80% done. As I read many manuals and engine builing books, of course, there is sometimes conflicting information. When installing the main and connecting rod bearings, I lubed the receiving side of the main caps (machined portion in the block and "inside" of the main caps) with 50 weight oil, and then gently pressed in the bearings. I did the same with the connecting rod bearings. I came across an old article that stated that the receiving end should be "clean and dry".
Any thoughts on the above? Would lubing the back side of the main bearings and the connecting rods be detrimental to the build? Everything spins nicely, and there are no sticking spots.
Thanks for the help.
Thanks again.
