I have a set of 1.6 Harland Sharp roller rockers and a Comp cam 274/286 hydraulic for by 440. I purchased an "adjustable" push rod with a ball end and cup end to check the measurement, but was not certain how to get a precise measurement.
I imagine that the rocker shafts need to be torqued down on the heads, and my thought was to measure the push rod length off the heal of the cam (i.e. - fully closed) to garner the shortest measurement. Is that all correct? Should I be starting with #1 at TDC as a reference point, and if so, which valve should I use to measure? Finally, do you need to take multiple measurement points and take an average?
Thanks for all your help with this build.
