by Eddie » 30 Apr 2007 20:13
I don't know what type of heads those are. Maybe Dave or Barry could shed some light. As far as the valves make sure of the number of grooves on the valve stems. Are you going to use the stock original valve retainers and locks,(keepers)? be aware that some valves had single ,(intake usually), and double or triple grooves in the stems,(exhaust usually). Or if you are going to use new valves, retainers,keepers then none of this matters, are you going to install hardened exhaust seats?BTW, the max wedge heads have 25% larger intake ports than the standard B/RB intake ports and this is readily apparent as you lay an standard intake gasket on the ports! Also Dave is right, build that bad boy with Max Wedge heads and you would have an High RPM screamer. Those 383 were tough engines. I couldn't blow one up and tried many times as my old man beat my arse many times over it!!
