 by john » 05 Dec 2001 5:48
			Bill, that is a darn good point and mine were cross firing bad. I had cheap wires that were only 6 months old but didn't stand up the heat I'm guessing. One night I opened my hood while the car was running and I saw a nice lighting show. I quickly bought a new set. I spent 100 dollars on accell 8.8 mm high temp wires that have stainless steel under the outer layer that is supposed to help stop cross fireing. I thought I had the problem licked but no it is still there. O.k., should my intake get hot enough to boil a drop of gas or singe skin if touched? If not mine does,why is this? If that is not normal how can I fix it? My temp gauge always reads in the norm and the radiator has never boiled. I've driven it on long road trips with no problems. Here is something that may or may not be part of tha puzzle. Just before this road trip I discovered that my car did not have a thermostat. The car never came up to temp, atleast according to the gauge. I had assumed it was a faulty gauge or sending unit and replaced both with no change. So I took off the thermostat housing and no thermostat. So I put one in. Maybe temp has something to do with it but then I think of a cold start and it will ping. Maybe there is something to Dave's idea of one cylinder heating to hot. I do have headers on this car. Maybe a header leak is making things to hot. If there is a leak I haven't noticed but I have been so focused on the ping. The headers are old and have been with the car for quite a while. Could they cause the temp under the hood to climb to high? The problem I have with people around here touching it is noone carries 70's service manuels anymore and very few if any do I trust on carborated engines. No manuels and no experience I'm not spending the money for someone to stare at it anymore. I just don't know anyone with the knowledge and equipment.
