by yaro » 09 Nov 2006 14:18
Hi
You are right - I have iron heads and quite mild cam from Hughes (duration 223, 230 at 0.05") and also stock distributor.
I modified timing curve from stock and I spend one day on a dyno to set distributor and timing for max output of the engine, but with vacum advance conected is not possible to get rid of pinging. Without I do not have any problem except one - fuel consumption.
I am thinking about thicker head gasket, to lower the compresion to 10,5.
On dyno I checked also AFR and iy seems to be a little to lean (but plugs are nice and tan) and lean conditions also can cause pinging.
I have Edelbrock carb, I went one step richer, but pinging is still there, so maybe I have to go one more?
Also although mild cam my engine is rough on idle and produce a lot of noice (not from exhaust, just engine itself). When I compared it to another big blocks my engine produces such a big amount of noise, almost like diesel. Could it be caused by compression ratio?
