dave-r wrote:Can i just add my thoughts before he answers?
Gave you a headstart there, didn't I?
My thoughts on this problem, although mine never gave up (I have the orange box on the convertible) :
Original electronic ignition cars (1972-) had the ECU on a bracket, on the firewall. Plenty of air circulating behind the bracket, so the bracket itself was probably acting as a heatsink (and of course, the transistors, at least for this kind of application, were of better quality then). Most cars that were retrofitted with electronic ignitions (and mine is no exception) have the box mounted directly to the firewall or inner fender. As Dave said, electronics and heat don't mix. I've even seen one car in which the inside coating had dripped from the ECU on the firewall (stock model, not orange box).
For american people out there, there are several replacement boxes available at parts stores (Napa and the like) that have a better reputation than the Mopar boxes. I'd say that Mopar has them made by the lowest bidder, and the components are not of the utmost quality.
That still doesn't explain their rate of failure, but I'd say that the components inside don't stand vibration and are not rated for automotive use.
Such problems happened twice recently to friends of mine. One was a real box failure, the other was a transient problem with the ballast resistor. Anyone using an ignition system with a ballast should also have a spare, or arrange the wiring in a way that lets you bypass the ballast easily (it's easier to think about this in a heated garage with lights on, than by the side of the road in winter, or under the rain, at night, with no tools).
the FBO system looks stock and is considered reliable by most people who talk about it (on moparts, mostly).
