Jon wrote:What heat range are you guys using , say in the Champion line. I am having FBO recurve my stock electronic distributor and Don says I may now experience some detonation. I have been using the stock RN9YC with a purple shaft cam and iron heads with no problems. But that was with limited total advance in the stock curve and ECU. Would a colder plug help?
Only change the heat range of the plug if the plug tells you it wants changing. As i said in another post the other week, The ideal timing curve is made by advancing the timing at 2000rpm, 2500, and 3000rpm under heavy load and seeing how much timing you can dial in at each rpm stage before detonation. Only then do you know what the ideal timing for YOUR engine is.
Don seems to time everything as if you are driving a light weight serious gear full race car.
I bet he said you "need" about 18 degrees initial timing as well? He usually does.
Now this is what I don't understand about Don. Why would he change your timing to make your engine detonate? he should be timing your dizzy so that you get as much timing as possible WITHOUT detonation.
That guy drives me up the wall.
You cannot "guess" what the ultimate timing curve should be for ANY given engine. Even if it is the same spec. There are too many variables.
I don't trust Don and I don't like him.
Here is an example. His UK supplier gives me a one piece six pack gasket to try. The holes for the carb bolts work but are a few mm out so they don't center and the bolts are hard up against the sides of the holes.
Also the accelerator pump lever hits the gasket.
His conclusion? Chrysler manifolds were all drilled erratically so my bolt holes in the manifold are out. He used a super dooper new one to program his CNC gasket cutter that is super dooper special for some reason I can't even remember. So either my manifold is out of whack or I am just not capable of measuring anything.
So took some photos and explaned that the holes in each carb base match the holes perfectly in the manifold. The error in his gasket is not between carbs but is between the bolts FOR each carb.
His reply. My manifold is wrong.
Again I explain and photograph the gasket against the bottom of the center carb so he can see the holes in the gasket do not quite match the holes in the carb.
His answer. He can't make mistakes. I am an idiot.
He then went on to tell me how I have tuned my carbs all wrong and that my timing is all out of whack. He has never seen my car in his life and had no idea what it has run on the strip yet he is telling me I don't have any idea how to tune my own car that I have owned for 17 years?
What an a-hole.
(Sorry for the rant. Had a couple of glasses of whiskey.
