I have strange problem with my ignition system. It is all new MSD ignition with billet distributor and 6A - MSD ignition control. The problem is The ignition is set apprx 17 deg before , at the idle when i puch the accelarator pedal it first goes after and only later starts to go more before. Because of that engine is very sleepy when you kick the pedal only after a moment starts to go.
The other problem is with the idle speed.When we set the idle at the park position to 800 rpm, after changing to drive engine stops, i have to have idle min 1200 rpm to be able to put drive. The camshat is from Hughes engines and is relatively mild
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .506°
.524°
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .539°
.558°
Intake Duration at .050"
Exhaust Duration at .050" 223°
228°
Lobe Separation Angle 111
Intake Opening at .050"
Exhaust Opening at .050" 3.5° BTC
48° BBC
Intake Closing at .050"
Exhaust Closing at .050" 39.5° ABC
0° ATC
Min. Suggested Cylinder PSI 160
Sweet Spot RPM 1800 - 5400
i am also running 360 heads with big valves 2,02 and 1,6 + porting, + adjustable rocker arms
Edelbrock performer RPM intake
Speed demon 750 Cfm carb Vacum secondaries
Keith Balck dome pistons
compression ratio is 10,5 :1
all based on 318 block
The engine is not bad at higher RPM but it is absolutely weak at low
Sorry if i have made some mess in my explanation but i am not so good in mechanics.
