Siamesed blocks.
Postby plum-crazy » 20 Jul 2006 7:54
What's your opinion about?
Big siamesed blocks are bored to 4.500, but what is the reason to receive this name?
What is the real difference from typical big block?
Any cooling problems to continued street use or in the traffic jam?
Need to install a new radiator to keep the engine on the right temp range?
plum-crazy
Postby dave-r » 20 Jul 2006 8:47
As I think you suspect the cylinders are joined together down the middle (like siamese twins) so the water jacket does not completely surround each cylinder.
I am not sure that this matters on a street engine as long as the cooling system is good. I think the old Pontiac Firebird 400 inch engine was like this. Although that particular engine was prone to blowing head gaskets if i remember right but I think that was because the cylinder bores were very close to each other.
Postby plum-crazy » 20 Jul 2006 8:55
dave-r wrote:As I think you suspect the cylinders are joined together down the middle (like siamese twins) so the water jacket does not completely surround each cylinder.
Yes, exactly that.
I don't find information about the difference between 4.320 block and 4.500 siamesed block.
Why they call it siamesed?
plum-crazy
Postby dave-r » 20 Jul 2006 10:01
I don't know what you call then in Spain but "siamese twins" is an old expression that used to describe children born joined together. This used to be more common in the far east and in Siam in particular. I think Siam is what is now Cambodia or something?
Postby plum-crazy » 20 Jul 2006 13:48
Yes Dave, I know :mrgreen:
But the reason I want to know is if this name is due the right and left cylinders position or the reduced space between the same side cylinders until no space enough to water flow.
Other thing I'm not sure is the block called "mega block", is only for overbore or something more?
They are using the cross bolt main blocks, is this system used on each hemi?
plum-crazy
Postby dave-r » 20 Jul 2006 14:18
plum-crazy wrote:Yes Dave, I know :mrgreen:
I think the name gives it away. All four cylinder on each side are cast together. No space between for water. This allows for bigger bores without the walls getting too thin.
Same with Mega block. Cast with big bores they have much thicker cylinders and smaller water passages.
Postby dave-r » 20 Jul 2006 14:20
plum-crazy wrote: I want to know is if this name is due the right and left cylinders position
If the left and right banks of cylinders were joined together it wouldn't be a V8 would it? :lol:
Postby dave-r » 20 Jul 2006 14:22
plum-crazy wrote:They are using the cross bolt main blocks, is this system used on each hemi?
I believe so. I would have to check if the stock street hemi used the cross bolt mains. I can't remember.
