I had a good start with mine as the runners and bowls on these particular heads were professionally ported by Dave Hughes. Mainly in the bowl area. I have done my own porting in the past though.
I have done only a little more on the ports and polished the exhausts (as you should). I also polish the chambers but not to a high degree. Just enough so the carbon has less grip and there is less heat transfer from the cylinder to the water jacket. Smooth and shiney conducts a lot less heat then rough and black. The less heat is transfered the more cylinder pressure (torque) you get and the cooler the water keeps.
They also steam clean up easier with just dripping water into the carb while holding the rpms up.
Don't remove material from the inside of curves in the runners. What is sometimes called the short radius. Just grind the outside of the curves. Any port matching must gently blend into the runner over a half inch minimum. More prefered.
Keep up the good work!
