This is normal for a stock carb on an engine with a hotter cam.
Read my posts about carb tuning. You don't say what make carb it is so the cure will vary. But basically the idle circuits are not delivering enough air and fuel at idle.
The idle mixture screws can in most cases deliver enough fuel but usually not enough air. The simple cure on most carbs is to drill a couple of small holes in the primary throttle blades.
But some carbs have an adjustment that does the same thing.
Welcome to thw world of carb tuning.
