I've read through quite alot of the historical posts first.
I'm having trouble sealing the passenger side valve cover on my 1970 440. Checking the great breather/pcv info you gave also.
I believe I read about making sure the drain holes are clear in the heads. Send wire thru hole to pan to make sure.
I had my cover off today for another go at sealing them.
I could not find ANY type of small drain hole in either corner.
The heads are very clean inside though there is some standing oil at the bottom of the gasket flange on the head.
Do you have a pic of where these holes should be exactly?
Any sealant/gasket brand/types you recommend for a good seal for a seldom driven street car?
The valve cover is fairly straight but could use some help.
How do you go about straightening the cover flange? Small hammer and an anvil?
p.s. Great Site. I'll be around for a long time!
