Hi,
I am going to rebuild my 383 engine and I have a question if I should use a carburator spacer or not.
engine 383 .030 oversize
Comp cams extrem energy 274/286 .488 .491 lift
flat top piston 9.5:1
516 heads 2.08 1.74 valves
Edelbrock Torker intake
Holley 750 DP 4779
Hedders
2.5" exhaust system
Converter stall 2500 rpm
rear axel 3.23 ratio
the car will be used as a street and strip car
my question is:
should I use a (4 hole 1" spacer) or a
(1 hole 1" spacer) or should I go without any spacer at all.
//Roland
