6pack rebuild kit
Postby 1211 » 14 Nov 2005 8:34
Does anyone sell complete rebuild kits for all 3 carbs in one kit? Or are you stuck with buying a $70 kit for each one? Something similar like the Holley kits that have all gaskets, power valve, needles, etc. I just noticed the rear carb spouting out fuel like the needle was stuck open. Thanks
1211
Postby dave-r » 14 Nov 2005 11:14
I don't know of any non-holley kits.
Where was the fuel coming from?
If the fuel bowls are flooding it will just be a bit of dirt in the valve seat in the top of the bowl. A good clean should do it.
If the fuel is coming out of the accelerator pump nozzles at the top of the carb that just means the adjustment on the accelerator pump lever is too tight. Back it off so there is clearence.
